MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 60,235
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
I have a 4 cylnder gas engine in my IH2500b. I am getting no spark at the plugs.
I pulled the plug wire that goes between the distributor and the coil off the distributor end and layed it near some bare metal and cranked the engine. Nothing.
I measure 12V from the + terminal on the coil to ground and on the - terminal to ground when the key is in the on position.
I have the ignition side wire going to the + terminal on the coil.
I have the - coil wire going to the distributor.
I've changed the coil and still have no spark coming out of the coil and all the same measurements as listed above.
Any suggestions would be greatly appreciated. Thanks in advance.
