RoyJackson
Rest in Peace
- Joined
- Nov 17, 2001
- Messages
- 24,890
- Location
- Bethel, Vermont
- Tractor
- John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
</font><font color="blue" class="small">( Try a 5 footer on that machine. You can always shift down or take less of a bite, but a 48" will never cut more than 44". You won't cut big stuff only the first time and if it is to big hire a rig for the rough mowing. bcs )</font>
Although I'm normally a proponent of 5' cutters even on machines with less then 20 PTO HP, I think a 5' unit would be too heavy for the 2210 (or any other subcompact). The 2210 weighs (unballasted) 1300 lbs. A typical 5' cutter weighs 600 lbs minimum. That just under 50% of the tractor weight.
Powerwise, the 2210 is right at the bottom of the scale...but I used a 5' cutter behind a 16.5 PTO HP Deere 670 with no problems.
