Great repair. I had the same problem and put 5/16 x 3/8 dowel pins in the front and the back. It was tough. It took 4 try's. The only way you could get them to go in was to put the front in first and then stick the pins onto the back shaft with grease and then slide it over. If you put the pins in the coupler, they are too long and will not go over the shaft. I tried putting them into the back coupler, and putting the shaft in there last, but the couple needed to go back to far and the pins would push out. Once I put my thinking hat on and did the way I described, it worked the second time. Good thing I ordered 20 pins necause there is snow outside and that is where I was doing the repair. By the way, I got the pins at fastenal for $.25 a piece. My shaft was worn, but I did not get it repaired. I am thinking with the dowel pins, I will not have to. I have not tried it yet, but the shaft felt tight. I will report on how it worked when I use it.
