Re: 5\' or bigger implements by Compact Tractors?
I see, this weekend, I will be busy with enlightening some people here. First of all, let me summarize HP & Torque & RPM relations briefly.
HPt = Theoretical HP (perfect HP, when efficiency is 1, when fuel is burned completely, etc.)
HPr = Real HP
T = Torque
R = RPM
E = Efficiency
Formula is:
HPr = HPt x E = T x R
When you add a turbo actually you are increasing E (efficiency) as you are recovering heat loss and by heating inlet air/fuel mixture, better combustion in the engine. So, you have a theoretical HPt that is maximum and now, with a turbo, you have a bigger HPr. Engines and vehicle components are (must be) designed according to HPt, not to HPr. This means you are allowed to increase your real HPr up to theoretical HPt. If you can.. Turbo can. Current turbos in the market can increase HP by about 20% (still under theoretical HPt of course.) SO, don't worry about increasing your engine's real HPr, you will still be under the design, theoretical HPt level. Having said these; now, lets see where your increased amount (20%) of HPr will go if you increased it by a turbo;
HP = Torque x Rpm
HP will stay constant at any point of the system (at crankshaft exit, at flywheel, at pto output, etc). Depending on your gear, flywheel, etc you will increase either T or R, but their multiplication (i.e. HP) will be constant. In cars, R is increased, therefore T is lowered. In tractors, T is increased and R is lowered. So, if you increase HPr by 20%, and if you keep Rpm same, where will that extra HP go? It will be converted to Torque that will carry the load. Okay, everythings up to now is clear? There will be no strength, stress, fatique, durability problem as our increased real HPr is still under theoretical HPt that can also be considered as design HP if your tractor is a well designed, quality tractor.
Now, why am I bringing such an issue here? Someone had asked me to send him some drum mowers and tillers. I offered some (between 5'-7' sizes) which are designed according to 35-45 HP. He said "these sizes are big as we will use them on compact tractors which have >30HP". I said you can of course use these 5 - 7 ft implements by your compact tractor. And, if you do that, you will get a better pricing. Dealers/manufacturers (of such 35-45 hp implements) out there must be rubbing their hands now. They will be selling much more quanitities of bigger sized drum mowers, tillers, etc to compact tractor owners. Now, this is serious thing if you believe me? I go out now. Later. have a good weekend.
