Podunkadunk
- Joined
- Jan 2, 2007
- Messages
- 1,182
Guys, I need to relieve some steam. I took my Kubota in to the local dealer last Wednesday. They were supposed to have it back to me by last Friday, but didn't call. They finished it Monday around noon and I had to call them to find that out. I went and picked it up Tuesday, early evening. I brought her home, put her in the garage. I hadn't bothered with her until today.
That's where the trouble starts. First, in a previous life, I was a Flight Engineer. Isn't much about my particular aircraft I don't know. I'm also an FAA Airframes and Powerplant Mechanic. Not boasting, just establishing my attention to detail and I absolutely insist on the same standard of excellence when it comes to my stuff, as I would do if I were fixing your airplane...
Anyhow, being that it was the first service, I figured I'd let them do it. They gave me a song and dance (when I bought it last December) about how the first service is the most important, how it looks good for the warranty if something goes wrong (if they did the service), blah, blah, blah. I know that speel is BS and a 2 year warranty is a 2 year warranty. Truth is, I just didn't feel like doing it nor having to dispose of umpteen gallons of hydraulic fluid and engine oil. Anyhow, that's not the issue.
The issue is this. Since I don't trust anyone (call me paranoid or whatever, it's cool) I marked (inconspicuously with a red 'sharpie') each bolt that had to be removed to drain fluid, marked the filters (all 4 of them, it's an HST) and made a lot of "mental" notes of the situation.
I was going to go do some pasture bushhogging today, so I FINALLY go out to the garage for a little quality assurance/spot checking on their handy work.
Here are my notes:
1. Oil quantity is overfilled. Cold engine, oil level is 3/4" ABOVE the FULL line! That's unsatisfactory!!!!!!!!!!!!!!!!
2. The tranny hyd. fluid level is 1/8" BELOW the LOW line! (Yes, the 3 point is in the fully lowered position).
3. Somebody (in their infinite wisdom) decided they would adjust the toe-in on the front tires. Oh by the way, it's not due until the 200 hr service. The toe in was already in limits (5/16"), because I check it regularly...(I know, I'm geeky like that). Anyhow, the right tire tie rod nut was backed off 4-5 turns! Believe me when I tell you guys that it wasn't that way when I dropped it off with them!!!!!!!!!!!!!! It was tight and jammed against the stop!
4. The front axle has 2 bolts that are required to be removed to properly drain the oil from the front axle assembly. Guess what? Yep, they removed the left side, but not the right. Ironically, the left side also has the bolt you remove to check the fluid level and the filler bolt. That's right, they only let out probably 1/2 of the front fluid. Because the right side bolt sits low, it's impossible to drain all the fluid from just the left side. SoB's...
5. Tranny hyd. fluid draining. There are 4 bolts that must be removed to properly drain the hyd. fluid. Guess what? Yep, you get a trip to Aculpulco!!! ding, ding, ding....Nope, they only removed 1 of the bolts. They removed the larger one in the middle and bottom of the tranny housing. There is one more just forward of that one and 2 back in the back, which, sit low and there's no way to properly drain out all the fluid if the rear two aren't removed. So, those arseholes only drained about 3/4 of the fluid.
6. This may be "nit-picky", but to me it matters. On a 50 hour service, they are supposed to grease the battery terminal connections. They didn't. They are dry as a desert bone. I would have let this go if not for all the other BS.
7. They wrote on the invoice sheet that they washed the tractor. NOPE, if anything they took it through a mud hole. When I took the tractor in, you could have eaten off any part of the tractor. I run a tight ship. I keep my tractor clean. There wasn't a speck of dirt on it when I dropped it off. Man that burns me up.
After I did my inspection, I got on the phone and called the service manager. I told him that this was unacceptable and that I was highly upset. I think that part was a no-brainer since I was using expletives that MikePa would ban me for if I used them on this site.
Long story short, they are coming to pick it up tomorrow and take it back. I told him that when I was in the Navy, if I had done my job like that, people would have died and I would have been amongst the dead! He was like "yes sir", "sorry sir", "I'll fix everything sir"....blah, blah, blah.
Why don't they just come out and tell you the truth? You know, we cut corners, overcharge, overbook the maintenance shop, crack the whip on those guys and demand that they do a specific number of units a day, all at your (the sucker who brought it in) expense, because half the dumbarses out there don't know shat from shinola and don't even know how to check the oil, much less read their owner manuals... (disclaimer, sentence is a "run-on" I know...I did it to illustrate my point better).
Word to the wise for all you newbies to the tractor industry like myself.
DO YOUR OWN MAINTENANCE, AS I WILL DO FROM NOW ON!!!!!!!!!!!!!!!! Don't trust anyone. Those guys are good people, I don't doubt it, but it's kind of like your wife taking your car in to the mechanic..."ma'am, you need a new tranny (when she came in for a new alternator belt). They'll do you in the drive-thru!!!
I wonder how many schmucks go in for all their services and get shafted like this...and don't even know it?
I feel better! I know it was long, but thanks for listening guys.
Podunk
Here are my notes:
Podunk
