955er
I was mowing over the weekend with my 955, I went to change the depth of the mower, and the control knob would not turn; it was stuck. It would not turn in either direction. I took the sheet metal off and got a large crescent wrench on the bolt. I was able to turn the bolt the half turn I wanted, but it took some effort.
I took a brief look at the mechanism, and it seems like there is a gear/shaft type of arrangement that lifts or lowers the arms. Is there some grease fitting I am missing that needs some attention, or do I need to take the deck off?
I should add that it has always worked in the past, and I did try it with the deck in the up and down positions, with no change. Any help will be appreciated. I did do a quick thread search and found no help.
Thanks in advance!!!
