Mechanos
Veteran Member
I freed the back of the mower and dropped it down and the rotary dial works fine. But there appears to be something missing, the shaft from the hydraulics
piston is not attached to anything, but looks like it should be attached to the deck raising\lowering mechanism. Also there is a rod coming from the 3-point hitch that is not attached to anything, but looks like it should also be attached to the raising\lowering mechanism. If anyone has a picture of what everything should look like under the top plate concerning deck lowering items, I'd appreciate it, as the JD manual does not show much at all. Thanks for any help.
Standard MMM raising/lower mechanism is linkage from the rockshaft to lifting mechanism. There was an optional hydrualic lift cylinder kit that would use the loader bucket valve to raise lower the MMM deck. If you have the optional lift cylinder kit, then the linkage from the rockshast should be disconnected.
