Correct me if I'm wrong. I am looking at this welder because A. It is cheap for how I use a welder. B. because it is an inverter, and hopefully with less current draw, I'm thinking I can use it with my 5000 watt generator which has a 220 volt plug but with only a 20 amp output socket which seems problematic with the 205 amp Hobart AC welder. Otherwise I would have to consider a mig welder.
A = Yes, same reasoning for new machine purchase here
B = Maybe, the "Current Drawn" will be determined by the Amp setting selected for welding.
A 5000 watt (continuous) generator should burn 1/8 inch rods using Amp settings 90 - 120 Amps without problems. If to much current is being drawn from the generator its circuit breaker should come into play and stop the welding process. The Hobart unit should weld fine with a generator if selected Amperage does not exceed the generators output (around 140 welding amps).
I will again restate my main reason of purchasing a unit using Inverter Technology, the "Size and Weight" for portability.
The units cost is also a deciding factor, a Miller Maxstar 150 S at $913.00 US is way out of my budget and unjustifiable for minimal projected use.
As for reliability, I'll say you get what you pay for. Then again, even high end units can fail, electrical devices have always had horrible warranties because of their nature.
Rhett
