s219
Super Member
- Joined
- Dec 7, 2011
- Messages
- 8,608
- Location
- Virginia USA
- Tractor
- Kubota L3200, Deere X380, Kubota RTV-X
In my younger days I had the opportunity to do some maintenance and repairs on a Euro version 308 GTB. Did a clutch in it and cleaned and synchronized the weber carbs. It was a bit of a beast to drive. The American version had hydraulic clutch and fuel injection but the euro version had a mouse trap linkage like and old Harley and weber carbs. I did get to pick my wife up for lunch on a test drive one day.
I have always liked the looks and even to this day it seems beautiful to me and sort of a timeless design. If I ever win the lottery, I would buy one to restore for sure, since I think you need a flexible/infinite/unending budget to be realistic about it.
I hear the belts need to be replaced often, suspension bushings are a frequent issue due to rubber breaking down and no/few grease fittings, and they are ripe for body rust problems in certain areas due to poor design that doesn't let water drain well and the use of raw steel panels with no coating/plating on the inside (so a frequently washed 308 is probably worse than a neglected one). Beginning in 1984 they used galvanized steel which helps a bit.
In general, I think the idea of buying one is about as smart as a self inflicted gunshot wound to the head, but I would still like to try some day.
