JDTank
Platinum Member
- Joined
- Oct 5, 2010
- Messages
- 695
So here's the latest.
Picked up a new battery this morning, and she fired right up.
Now, I have to mention, I tore out all the factory wiring and installed a push button switch for ignition. I believe I wired it correctly, and now that I check the output voltage, it's very low, 7.5 idle and 10.6 at full throttle. I ran 12 volts from the switch to the starter solenoid. I ran the ground wire from the coil to a toggle switch to kill the engine when I want to shut it down. I also ran the red charging wire to the battery.
Considering the machine was dying before for months with the factory wiring, I am guessing the charging system is on it's way out. I don't have a clue how to repair any of that stuff, or get the flywheel off, so it looks like it will have to go in the shop, or be boosted for the next 4 months and charge the battery every time we are finished with it.
