Obed
Elite Member
clemsonfor,I bought the $30 HF grinder and it works as well as $100+ grinders I have heard, I recommend buying this one.
Also if you use stihl oil it has stabilizer in it so you don't have to use stabil with it as there is already a stabilizer in it.
Also don't forget to file down your rakers every so often, if you don't know what this means or how to do it look at a youtube vid. I use to file rakers every 3-5x of hand fileing. I now hit it about every 2-3x of grinder sharpening. But the rakers is the shark fin thing between the cutters. It controls the depth the cutting tooth is allowed to go. If you file it to much you can get the saw pulling you around or if you put to much pressure on it and its to low you can bog up the saw, to tall and you will take forever to cut anything. I rather have them to low than to tall.
My 20" Poulan has been cutting very slowly, even right after I had a local shop sharpen it. I watched them sharpen it but they did not file down the rakers. I'll have to check the rakers and see if they need filing.
Obed
