B2320, B2620, B2920 cab suggestion?
   / B2320, B2620, B2920 cab suggestion? #1
eb542
  • DSCN1338.pdf
  • DSCN1562.pdf
  • DSCN1584.pdf
   / B2320, B2620, B2920 cab suggestion? #2
I know that Sims has one in the prototype stage right now, it should be available within a month. They're looking for a tractor right now to test their design, depending on how close you are to them, (they're located near Cornwall Ontario) they'd probably give you a good discount if you let them use your tractor.
   / B2320, B2620, B2920 cab suggestion? #3
That Sims link you provided has a cab listed for the B2320, 2620, and 2920 that is coming soon. For $3875 I think I'll be going with the "Carhartt" cab instead. And my mad bomber hat... :D
   / B2320, B2620, B2920 cab suggestion? #4
OH yes, The Carhartt snow suit. That is what I do. And if it is too cold for that then I don't want to be out there anyway! Plus it is faster to remove in the spring to get out of the way!:)
   / B2320, B2620, B2920 cab suggestion? #5
For some reason, my Artic Black Carhart had become tighter in the Belly Area last year.
Hung it up in the spring.. May need a new fitting by this winter.. Don't Understand how this happened.
Tom
   / B2320, B2620, B2920 cab suggestion? #6
Yes, I was shocked to see the price of cabs :eek:
I got my 2620 in May, then shortly after that found out that sometime next month I will be without a job (along with 500 others). Needless to say, I won't be spending $2000 - $3000 on a cab!!! The problem is, I've been spoiled by the Original (soft) Cab on the Gravely I've used for snowblowing for the past number of years.
I've decided to make my own cab. I am in the process of pricing the components, and trying to find a "molded" roof.
With today being the first official day of Fall, we all know that Winter is coming :D
I hope you will be posting a few pictures of your project.
Thanks.
   / B2320, B2620, B2920 cab suggestion? #8
The Original Cab Co. has their soft cabs available for the JD 2320, etc. but not for the Kubota B series yet anyway. It would seem they would do something with that since more Kubotas are sold than JD's in this size range. I wish they would since they start at $750, and are pretty well made.
   / B2320, B2620, B2920 cab suggestion? #9
I'm beginning to think GRA123 is no more than a shill.
   / B2320, B2620, B2920 cab suggestion? #10
GRA123,
This is the 4th ancient thread that I see that you have dredged up about soft cabs for small tractors. This is not a helpful use of the TBN site. The conversations have come to an end. I have to wonder if you own the covermytractor site. What you are doing is not an appropriate way to advertise. Please participate responsibly in current and relevant conversations.
