galstaf
Bronze Member
Hey all,
I have a 2015 Kubota B26 that just stopped moving (mostly). It will move a bit.. better forwards than backwards.
It is extremely weak in both directions (forwards and back), and makes a whining noise.
If the reverse stops responding altogether, it can help to push forward then reverse if that gives anyone a clue... it will move very grudgingly in both directions, so I am pretty sure the linkages must be functional.
I didn't change anything.. the machine ran normally, then just got worse and worse over the course of a day until now it can barely move forwards or back.
Checked the hydraulic fluid levels and they are fine. I even topped it up with Kubota SUDT2, and it just threw out the excess all over the back of the machine.
The FEL and BH both work normally and are still fairly strong. From what I have been reading, I am looking at the filters, but wondering if it is anything else could be the issue here.
Can anyone help? Does this machine doesn't have the mesh screen that seems to be an issue on some of the other models?
Thanks in advance for any help!
I have a decent mechanical background, but just getting used to tractors, so please be detailed with any answers.
