Quote:
Originally Posted by Opti-Mist
The worst thing to do to a tractor is "baby" it. The engine is designed to "work" and light loads are undesirable and result in things like oil consumption and blow by as rings don't seat, etc. On the other hand, one does not want to lug the engine either.
It's only a misconception in your view. Operating a diesel at low ERPMs doesn't allow the engine to reach operating temperature. A cold diesel is an inefficient one, leading to more combustion residue in the crankcase oil and unburnt fuel coating and perhaps eventually plugging the exhaust system. As Opti-Mist says, piston rings won't seat properly under light load/low temp/low ERPM. Hydrostatic transmissions suffer at low input RPMs because charge pressures can be low, oil flow to the oil cooler can be diminished, and the transmission's ability to transmit torque at low input speeds is a fraction of what it would be at rated speed. Consequently, hydrostatic oil temperatures can actually be higher than normal in this scenario. You may think you are doing yourself and your tractor a favor, but actually you are risking killing it with kindness. If you can run your tractor's cooling system between 180 and 210 or so, and keep clean engine oil in it, it's pretty hard to hurt the engine. A steady diet of cold engine is just as lethal as overheating, just slower.
Then I suggest you consult for the auto and truck manufacturers.
They would just LOVE TO KNOW that diesel engines in cars and trucks NEED to be run in the lowest possible gear to keep the revs up and "seat piston rings properly".
Do you have ANY IDEA what the cylinder pressure difference is between idle and max revs ?
and what difference that makes to "ring seating" ?
{quantitatively}
The auto trannie shift algorithm is biased toward keeping the engine at the minimum revs that will do the job - I guess that is "WRONG" by your logic ?
Some folk in Detroit need to hear from you, maybe that is why they went broke, help 'em out will Ya ?
Hey, I drive in traffic, the truck idles, sometimes for longer than I actually USE my tractor.
Would you have me apply the brake and step on the accelerator JUST to keep the engine block warm and happy ?
and you will argue that tractor diesels are different, HOW ?
