schmism
Super Member
Your tractor does not have enough power to bend a PTO shaft? At a minimum you have a very good chance at wasting a shaft if you hit something with the front of the cutter.
quite frankly i dont see how you hit something with the front of the cutter.
1) the entire front of my cutter is open to the world, else the grass/weeds/trees/brush would never make it to the actual blade.
1.1 ive driven over and flattend anything "soft" and anything hard (like a 6" tree) i just run into with the front of the tractor, and we stop that way.
2) the only part of the cutter that extends down to close to ground level is sides.
3) on my tractor when you run a 3pt low enough that the cutter is in the right height, your in the float postion on the 3pt which allows the impliment to rise up on the 3pt arms but not drop below the preset lvl. so the front of the cutter rides up ontop of whatever concrete block i managed to not notice when i drove over it with my wheels as the sides of my cutter follow just on the outside edge of the brush hog.
no my tractor doesnt have enough traction on dirt/grass to generate enough force to jam the front edge against an immovable object, fling the back end up (not ride over) and bend the PTO shaft in half.
you suggest things that just can not exist in the real world for a whole number of reasons.
