RoyJackson
Rest in Peace
- Joined
- Nov 17, 2001
- Messages
- 24,890
- Location
- Bethel, Vermont
- Tractor
- John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
Spiveyman said:So back to tractoring 101. Today's topic the clutch, and what you have to do to wear one out. While I was first tackling those mounds of dirt in 6 foot high weeds I was moving very cautiously, unsure of what I might drive over. I was also babying the box blade a bit to see how it would go. For much of this time I was on and off of the clutch quite a bit.
Is there a better way to do that? To control your motion? Using the throttle was too jerky and didn't seem like a good option. With the clutch I felt like I had pretty good control over things, but I was afraid I'd burn it up. Will that tear up your clutch or is that exactly what it's for?
I suggest you use a lower gear and judiciously use the throttle (use it...you'll get smoother action soon enough) and your tractor's differential lock (if equipted). Also, the hand throttle helps. You've just got to figure out the combination of actions and adjustments that work in your situation. And, a lot of that is trial and error.
Moving slowly in high weeds makes a lot of sense. I don't do it...I'll mow the high stuff before any loader work (just did that this summer, BTW). I want to know what under that stuff before I do any type of work.
BTW, if that toothbar hasn't arrived yet..can you hold off untill it does? At least, for the loader work?
Heed what those folks say about not riding the clutch!
