gwdixon
Elite Member
Oh, well thats helpful. Although I am not sure about "widening" the rear gang?
Does the adjustment to set the angel of the rear gang result in a wider cut of the disc?
Actually, it is more than just adjusting the angle. Loosen the U-bolts on the carrier bar and slide the whole gang out on each side. That is how the wider cut can be obtained. As mentioned, they are set narrow for shipping and delivery.
It does reduce the area a bit that is double cut by the front and rear gangs going over the same ground but it is not enough to make a serious difference or degrade the discing to any extent.
