Toyboy
Platinum Member
Just a thought...... instead of using all the washers to make up the difference on the bottom, would a small piece of PVC pipe work or is the space too small?
That would work too. I used fender washers as that's what I had easy access to. Keep in mind the hole in the loader bracket is like 1" diameter so PVC would require some additional manual centering.Just a thought...... instead of using all the washers to make up the difference on the bottom, would a small piece of PVC pipe work or is the space too small?
Thirdroc - Nice work!
Where did you get the tire chains for the front tires? Was there an issue clearing the hub?
