arrow
Super Member
True. But a matched pair of oversized tires on one axle will be problematic on a 4WD Tractor. That is my point and it is a valid one.
Yes and no. Depends on the manufacturers tolerance ratio to roll out comparison which can be anywhere from 2-5%. Less problematic of putting slightly larger tires on rears than fronts. A more definitive answer could be obtained by comparing first tire diameter of tires in question then multiplying that diameter times pi and then by a median 97% to get roll out for one revolution. Take the percentage of the increase between the two and see if it falls within manufacturers ratio parameters.
