DANOCHEESE
Put a VOM Volt Ohm Meter on the battery. Turn on the glow plugs. You should see a drop in voltage when the glow plugs are initiated.
I wouldn't say turns over briskly, but steadily.
Anything is gonna crank noticeably slower in low, low temps even with a brand new battery IMO, unless all my equipment is need of a charge/maintenance, which is possible
My TN70A is a bit slower, but not noticeably. Batteries take a real beating when not charged in cold weather. I always have a trickle charger on mine. If I don't, then my TN70A cranks sloooooowly. Battery is the key to a good start, no charger makes starting much worse. Next is oil viscosity. If those two are not fixed, the rest does not matter.
Bob
Speaking of a garage, we have an unheated
Morton building, the outside temp was about
-2 to 2 degrees but inside the Morton building
it was 18 to 20 degrees. A building makes a
big difference even if it's unheated.
