JimR
Elite Member
All the above items are good suggestions. I do have to put my 2 cents in. I spent 10 years of my life as a mechanic and the next 20 years as a machinist. If you are going to do the rings. You really should do the bearings and valves while you have it all apart. Unless of course the bearings are like new and show no wear. The valves should at the bare least be lapped. This is a real easy job using a small suction cup like tool you can buy for under $10.00 at any local parts place. They also sell valve-lapping compound. Buy the finest that they have. Check the valve stems for slop by pushing the valve side to side when it is about 1/4 open without the springs on them. Also look at the valve stems for any noticeable wear on the shaft. Why the rings would be gone with only 1300 hours is beyond me. Maybe the rings are stuck. I would not think they are worn out. Do another compression test by squirting 2-3 squirts of 10-40W oil into the bad cylinders to see if it is in fact the rings. If it is the rings, I would do the following to see if they are in fact stuck. First I would spray a lot of rust buster/nut loosener fluid into the 2 bad cylinders. In a few days I would do the following. Drain the oil and put in 3 quarts of kerosene and 2 quarts of oil. Run this for about 20-30 minutes at 1200 rpm's. Dextron II or III will do the same thing. I like Kerosene because it is lighter. If the rings are stuck this will surely free them up. (I did this on a Chevy 350 that was cooked from overheating. Lady didn't realize it until the motor froze up. The oil drained like mud and the motor had very little power. After I did my thing it was purring like a kitten once again.) Then change the oil filter and oil using 10-40W oil afterwards. Riun your tracotr for a good few hours and take another compression test on the bad cyclinders. If they are stil low. Drain the oil and put 20-50W in it. The heavier oil will help to seal the rings a little bit better but not much. This of course will make your tractor harder to start in the winter. I use to run 20-50W in my old Ford 8N because it smoked really bad. The change to heavier oil cut the smoke down to about 50%.
