Ir was nice this afternoon so I .cleaned the Transit per Ford recommedation. I pulled the MAF sensor out and gave it a bath with CRC MAF cleaner and reinstalled it. Then, I inserted the curved straw from the Sea-foam carbon remover and warmed up the engine to operating temp. Had my wife hold the rpm at 1400 and emptied the entire can of sea-Foam into the intake just in front of the throttle plate (takes about 5 minutes). Then I had her shut down the engine and I pulled the negative battery cable so the ECM could 'forget' any codes and habits and left it disconnected while I changed the spark plugs for new ones.
After I changed the plugs, I reconnected the negative terminal and told her to take it down the road and mash it...She did and I watched and the crap (smoke) coming out the tailpipe was alot. She went up and down the road 2 times, second time... nothing. She pulled back in the drive, the idle is very stable now and she said it 'seemd to have a lot more power. Definitely running very smoothly. Prior to using the Sea-Foan, I pulled the air boot and looked in at the throttle plate... it was very dirty. I looked in after and everything is nice and clean inside. Far as I'm concerned it works as advertised and was recommended by a Ford factory trained tech. Still have to add the PCV filter / catch can. Waiting for a new PCV valve and hose right now. Thats next, then comes the Focus. GDI
