Coyote machine
Super Member
- Joined
- May 4, 2009
- Messages
- 7,660
- Location
- Southern VT
- Tractor
- 22 SANY SY 50U, '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 BB, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Brush Mower. Diamondplate aluminum canopy
Have had retaining ring pulled out on the front deck wheels before, never the ones on the rear deck height adjusters. Have made sure the rings were on the inside for more protection.Did loose a caster wheel on the ZD.
Speaking of front deck tires, both went flat while mowing last week on my youngest F3680, (60 in). I had checked them for give by pushing on them, not using a pressure gauge. Has anyone else had this problem?
If the tire's pressures are low, or there is rust on the wheel rim where the tire bead seats when properly inflated the tires will leak air until flat. Since both went flat it would most likely be underinflation in both tires. Check bead area for rust before re-inflating. Best to use a gauge to ensure even, correct pressures, as the wrong psi will affect cut quality too.
