Does your tractor stay in or outside?
   / Does your tractor stay in or outside? #41
in side a unheated garage am in north eastern ontario have a block heater and keep a battery minder hooked up all the time . can go to -40 here so far no trouble starting with out the block heater well most likely would never start
   / Does your tractor stay in or outside? #42
Nothing i owe is left outside.
   / Does your tractor stay in or outside? #43
Tractor is always in shed unless it is being used for work.
   / Does your tractor stay in or outside? #44
I keep my '49 Ford outside, but parked under a carport cover.
   / Does your tractor stay in or outside? #45
inside heated to 55 degrees.... it always starts and fluids are warm:).
   / Does your tractor stay in or outside? #46
049.jpgI had a carport cover built for mine. The sun takes a toll on the paint around here.050.jpg
   / Does your tractor stay in or outside? #47
Mine is kept in the shelter since new for the off season but when the snow starts it gets to sleep in the heated garage so it can be ready to go when I need it. I only plug it in for the battery tender.
   / Does your tractor stay in or outside? #48
Inside an unheated barn, where it rarely dips below freezing, with the battery on a float charger.
   / Does your tractor stay in or outside? #49
Inside, heated garage, never spent a night outside.
   / Does your tractor stay in or outside? #50
StrangeRanger said:
Just wondering where you all keep your tractor. Do you keep in inside or is it outside? If it's outside what protection do you give it? Is it covered? Do you use a block heater and/or fuel treatment? Where do you live and how cold does it really get where it's stored outside?
Thanks,
j
We keep in our garage but we have a cottage in northern Quebec and its been out side with the block heater not plugged in and it's doing fine it's been -10 and started just fine but rolled coal for about 10 min:D
