LBrown59
Super Star Member
- Joined
- Oct 27, 2004
- Messages
- 16,851
- Tractor
- 2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
Anybody here have one?
LBrown59 said:Anybody here have one?
1971 I had a new Ford 250 camper special.JimR said:I had a Uni-Hoist setup years ago in my old Ford F250 4X4. It worked great for what it was. It is better to dump dowhill than to try and dump uphill just so you know in advance. Shoveling is required for overloaded pickups. An 8 foot bed filled flat with washed crushed cement sand weights 6000 pounds. Be aware of this should you try it sometime. Going through the scales at 11,200 pounds made the weight guy run out to warn me. I did have 13 leaf springs on the rear and was not dead axled. It was a scary ride home.
Ford960 said:The closest quarry to me will not load a pick-up truck or single axle trailer. It would really burn my butt if I paid $2500 for a Dump Pro insert and then find that I couldn't get it loaded with crushed stone.
I would suggest checking with the local quarry before buying one.
George2615 said:I think the local quarry won't load a pickup because of the liability of breaking the trucks suspension by dumping a load of whatever into the bed. That happened at a local quarry by me a few years ago. A loader dropped a load of crushed stone too fast into a pickup and the truck axle broke (snapped) from the sudden weight. In order to save a delivery charge the guy took his 1 ton pickup to get it filled. Ended up costing him 20 times the delivery charge he tried to avoid to fix his truck. The quarry took pics of the guys broken truck and have them posted in the office. Im asked to borrow them to post here but they wouldn't let them go. If you towed your own tractor loader and did your own loading then they might consider it. They will not be responsible for any damages caused to your truck or equipment.
