zmoz
In the past, I've read about and seen many examples of large engines turned into air compressors. Sometimes they convert the entire engine and drive it with another, sometimes they might use half the cylinders to drive the other half as a compressor. This sort of thing seems to have gone out of style with the advent of more modern air compressors, but I've always wanted one...
Anyway, I want to try and build one out of a V8. I have a running Chevy 350 sitting around doing nothing. I would love to let the engine run on one bank of 4 cylinders, and use the other 4 as a compressor. I was thinking I could remove the head on one side, and replace it with a flat peice of steel/aluminum with holes drilled in the correct places. I've played around with it before and the engine will run on as few as 2 cylinders.
What I wonder about are the check valves. I would mount two on top of each cylinder, one intake, one exhaust. What kind of check valve would I need for an application like this? Obviously I can buy a million different types of check valves online, but the thing is, it needs to be able to open and close as fast as a compressor works. This might wear out a standard check valve very quickly, let's say one meant for water. I guess I could try and make some sort of reed valve? Or maybe there's some part I could use from a 2 stroke engine that would work? The easiest would be to find a valve with ~1/2" NPT threads that could handle that kind of duty cycle...
Just thinking outloud here. Anybody ever done anything like this before?
