1) But not the cap?
2) You need to identify what the fouling is caused by, oil or gas.
3) Why? If it's running OK, you won't need hotter plugs. With a little work, you should be able to get any size plug in any heat range.
The cap also has been replaced. The engine is using Autolite 386, which is fairly hot.
The next heat range would be 387 and 388. But I'm tempted to use a 14mm adapter with Autolite 5164. The coil is a 40KV, so it should be able work with a modern plug. This is not going to break the bank as bad as a new carb.
Thanks guys, keep it coming. I am all ears.
