escavader
Veteran Member
SAME circuit seperately switched ,Seems funny everyone else like NY YANKEES FAN,is running all this stuff with no problem-same charging system.It does not take much to reach the limit of a 40a alt. Your heater definitely draws a lot, that coupled with all 4 of your work light on and you may have wiped out the alt. Do you have all the lights on the same circuit, or are they split up?
Tim
Battery tested at 12 volts off,started tractor with tester still on itno change.Battery light was on.turned up throttle ,light went out no change on tester still exactly the same .Alternator should have boosted voltage up to like 14 right? All electrics were off on tractor.
Neighbor said alternator should be magnatized ,this ones not???
Im gonna disassemble the new wiring harness and go over it one more time,then its going back to the dealer.
ALAN
