RaydaKub
Veteran Member
I finally checked the air pressure in my front tires, and the front right tire was low. I added air, and the pin went right in.
OK, I'm trying to noodle through this one. I don't doubt your fix. But since the front axle can rock, I don't understand how this would fix it. Did you move the tractor in order to inflate the tire? My point is that if the front tire goes flat, the front of the tractor goes straight down, not at a tilt that should cause binding on one side.
On second thought (even more noodling), the procedure for the BX is to lift the front off the ground and the pins come free. If the wheels aren't even on the ground, what difference does the air pressure make? :confused3:
