rbarker
Veteran Member
. I was able to rotate it, , then I grabbed the T handle and gave it a BIG pull and twist. It started to come out slowly, then all of a sudden popped right out! :cool2: Left pin came out easily, then I uncoupled hoses and backed away. Then I pushed the pin back in to the tractor mount without the loader, it slipped right in until the last half inch. There is a LOT of paint, and a small burrl.
Great! Sounds like you found the issue. I'm sure once you clean the burr and paint up the pin will slide in the way it should. If you can twist it you can usually get it to go in or come out.
Sent from my iPad using TractorByNet
