OK Stu, with the dump box open and secured, open the electronics panel that is on the back of the drivers seat. The starter relay is the second from the right with 4 wires connected to it. A fat B/W and B/Y, a skinny R/BL and B. Does this relay click when you turn the switch to start? If so, you should then be getting power to the starter solenoid through the fat B/Y wire. Now, after unplugging the connector, none of the wires will have 12v until you turn the switch to start, or all the way to the right. First, check that you have power on the fat B/W when you turn the switch. That is power from the ign switch. Next, check that the skinny R/BL wire has power with the switch turned. That wire is coming from the safety switches. If both of those are ok, the relay should be clicking when you turn the key to start. You should then be getting power to the starter solenoid through the fat B/Y wire.
