radioman
Super Member
Somewhere I read that RimGuard can foam if pumped too quickly.
I probably didn't see it in terms of how many gallons per minute or hose size, but it might be something to consider.
I might have sub-consciously avoided having to hold a cordless drill and pump for ???
some number of tens of minutes, you might want to check on what sort of flow rate you are likely to get, i.e. the boasted flow de-rated for viscosity, head, etc.
The passage through the part of the fill adapter that passes into the valve is very small indeed and is likely the limiter.
I noticed on the rimguard website that it can foam if pumped too quickly. I am planning on trying to fill my own tires with rimguard and i am hoping i dont screw up .
