RiverHill
Hi All,
I’ve lurked around on this forum for quite some time, but the realistic possibility of being a tractor owner within the month prompted me to join and get some insight, and hopefully reinforce my thought process.
We moved onto 26 acres nearly three years ago now, but officially bought the house and property last year. Now that we own our little piece of ground, I am in need of my own tractor which leads me to you fine folks. Here are our needs:
We have two TYM dealers within a reasonable drive. I like both and they have led me to the Branson 5520c. (I don’t like the layout of the TYM T’s.) There is an open house at one of the dealerships in two weeks, at which I expect to purchase.
We do have a local kioti dealer and I will check them out before pulling the trigger, but I like the thought of the kukje engine in the Branson with minimal electronics, and I’m partial to red.
My question for you all then, is whether this is a good fit, a good tractor, or if there are better alternatives to consider.
Thanks in advance!
TLDR.
Need to brush hog, maintain gravel road, and lift a round bale on 26 acres. Pick me a better tractor than a Branson 5520c.
- We have 3/4 mile long gravel road leading to the house, which despite being a township road is basically private and needs maintaining.
- We have a 10 acre field, and a 3 acre field which both need to be maintained. Father-in-law used them occasionally for pasture before he passed, but otherwise simply brush hogged them every year. This practice will continue until I can either pasture it more regularly (we don’t yet have any livestock) or I can put enough into the soil to improve the hay. It’s worth noting that the 3 acre field is very steep. I’m not sure I have the fortitude to brush hog it like my father-in-law did, so tractor stability will come into play.
- Ultimately, I would like to get livestock. We’ll likely either get a few horses, or a small beef cow herd, so I’d like a tractor with a loader that can safely move a reasonably sized round bale.
- I also want to have the ability to make hay, likely using a square baler, or if able a small round baler.
- Finally, I have a ton of small project ideas around the house that a tractor would help with including landscaping, minor dirt work, etc.
- 40+ horsepower
- 4 wheel drive (we’re in the mountains of PA)
- FEL
- Cab (this is admittedly a want)
Thanks in advance!
TLDR.
