Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 52,238
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Well, make sure there is no resistor wire in the harness.
The 000 series 3 cyls were 12v, but used a 6v coil, bypass solenoid and a resistor wire folded in the harness. I dint know if the 3600 kept the wire and 6 v coil or not. If yes, you either need a 6v coil, or bypass the resistor wire and run a 12v coil. The 12v coil I lil is a Napa ic14sb.
Check first
Check first
