mbro223
I live in the northeast corner of the state Leonz. Near Alpena on Hubbard Lake. I also live downstate near Brighton but its starting to suck paying for 2 houses!
Is there any reason the gear box can't be filled with grease like is often done with a bushhog? Mine leaks 90w or AW68 from around the pto "spud". How difficult/expensive to pull pto stub and reseal? I gave $150 for a ?48" (53" wide) Ford-917 with the duck foot hammer-knives.
Also is there a video or some sort of guide on how to sharpen the hamer-knives (angle and how sharp are the really suppost to be). I use mine to mow lawn, which is mostly coastal/pensacola bahia, and it leaves a lot if the seed stalks just beat up, till first rain when they stand back up.
It's called a banded belt (http://www.vbeltsupply.com/bandedconvetionalbelts.htm), and should be used rather than two singles. I think mine is a B63-2 or perhaps B64-2. Given all the idler adjustment, either should work. Banded belt = less slippage. Also, not only should the knives swing on the hangers - the hangers should swing on the brackets. Is you don't have that double flex, premature knife damage can occur. And no, one that knife there should be a matching pair of beveled cutting edges. A flat edge will result in a more ragged cut
//greg//
This old thread seems to be where the knowledgeable posters hang out -
I see a 74" offset 917 flail mower for sale. Claimed good condition, ready to use. I've read through the maintenance/repair suggestions here.
How much hp does it take to run this? I have a Yanmar rated for engine 24 hp / pto 20 hp that is roughly a 7/8 scale 8N in terms of what it can do. Also a 15/18 hp smaller Yanmar that is probably too small, its 3-point is rated to lift only 550 lbs. (both are shown in my sig file below).
Any advice welcome! Thanks.
Orchard grass occasionally up to 36". The reason I'm thinking of a flail mower is to better pulverize the orchard pruning debris (3/8", occasionally up to 2") that was overlooked gathering larger material for the burn pile. Also the offset will be valuable to mow closer to the trees without banging my head.I don't think there's anyway you'll be cutting thick 12" grass or weeds with a 74" @ 20 hp, let alone any brush. I have a Kubota L285, 28 hp @ pto and a 48 or 50" ford 917. I don't bog down in thick grass, although I often takes a trip back the opposite way to cut it well; but I don't think mine would work well over 60".
What are you wanting to cut?
The more I think about this - if a 50" needs 28 hp then a 60" is too big for my 15 or 20 hp Yanmars. Oh well... If anyone wants this, its on CL for $875. 2 hours north of San Francisco.I don't think there's anyway you'll be cutting thick 12" grass or weeds with a 74" @ 20 hp, let alone any brush. I have a Kubota L285, 28 hp @ pto and a 48 or 50" ford 917.... I don't think mine would work well over 60".
