quicksandfarmer
Veteran Member
A hydraulic HP calculator is here:
Genuine Metaris: Horsepower Calculator
8 gpm @ 2000 PSI =9.3 HP. At a rule of thumb of 5hp/foot for rotary mowers that means slightly under two feet. 25HP=20GPM +/-. Prince makes a PTO pump that is 21 GPM that is about $500. That should power a 60" mower.
Here's what I've dreamed about: replace the FEL bucket with a 3-point hitch receiver. Put a hydraulic pump on the PTO, and a hydraulic motor with a splined output shaft in the middle of the front receiver. Select the motor to have the same displacement per revolution as the pump, and the motor will turn one revolution for every revolution of the PTO. Presto! Front PTO that works exactly like rear PTO.
Then put mowers, PHD, etc. out front where you can see what they're doing.
