<font color="blue">4*I have been toying with the idea of making a hydraulic weed whacker that would attach to the FEL Mike_in_Okla
Visitor
===== </font>
4* <font color="red"> The following are excerpts from comments I've made about such things.
</font> ~~~~~~~~~
Power the head with it's own engine and you can change it from tractor to tractor either as a tow behind or attached or back and forth from one or the other.
Have you thought of using a string trimmer head and motor and eliminating the long curved or straight shaft?
I have a plan in mind for building something like this that solves the shortcoming of having to short of a reach by using and expandable / adjustable longer arm rather that a fixed short one like this and all the other similar devices I've seen have.
It would be universal as it could be mounted to or towed by any tow or host vehicle.
You could even attach it to a FEL or back hoe bucket or MMM or most any other implement.
It could even be used as a tow behind; or as an offset towed or attached.
Like the others it would trim around things such as fences trees etc. But unlike the others it would also trim along and over ditches.
I'm not leaning towards something like a boom mower as the hydraulics required greatly limits the number of host vehicles it could be used on as well as the number of ways it could be attached and or towed.
Now if only I had a welder and could weld I'd make an attempt to implement the plan.
1*That or a mower suspended from a frame that reaches out over the ditch.
2*I don't think the swisher has enough reach to cover a ditch that's 2 to 5 feet wide and these mowers would simply run into the ditch.
3* That's one reason for suspending the mower using either a boom or a suspended frame attached to the tow tractor.
Heck it could even be attached to one side of a MMM or towed behind like the tow behind mowers.
It should not matter if the wheels are in the ditch, The mower and all 4 wheels should be riding the slope of the ditch,
I'm not to concerned with mowing down inside a ditch, just with keeping the top of the weeds/grass growing down inside of the ditch about the same level as the lawn grass.
This is why I'm toying with the idea of an adjustable telescoping arm that extends out over the ditch.
The mowing device would be attached to the underside of this arm.
One of my ditches has sloped sides but the other 2 ditches have sides that are straight up and down.
One of the ditches can be trimmed from either or both sides, but the other 2 can only be approached from one side.
I'm toying with a combination / fixed tow behind incorporating a telescoping boom.
The unit could be built universal to use as a tow behind or it could easily be attached to the 3 point hitch, loader bucket, mmm , FEL arms, BH or as a tow behind on any tractor riding mower ATV etc.
