IslandTractor
Super Star Member
- Joined
- Sep 15, 2005
- Messages
- 17,101
- Location
- Prudence Island, RI
- Tractor
- 2007 Kioti DK40se HST, Woods BH
Westendorf-RR said:I think it matters more what is on the bottom (thumb) of the grapple. We see this every day in the ag market. Farmers who try to use their hay grapple to handle trees and logs... they don't get the best results. The top teeth are too wide and rigid to conform around the load. I should clarify my statement refers to a single rigid grapple over 50" wide mounted to the top rail of a solid bucket with sides (not bottom tines). What you have is on the same lines as our large BC-8800 unit - I'd say you'd get a little more of a secure lock on the load with two jaws, but I think you could make either work.
I think one of the points of confusion relates to different types of grapples that go by similar names. One man's standard grapple is called a root grapple by the next guy and a completely different clamshell style is also called a root grapple by some.
To my thinking there are two basic types that use different physics to contain the load. "Gravity" grapples, like mine, have lower tines that are parallel to the ground when loaded. In this case the upper jaw just stabilizes the load but gravity does most of the work. Millonzi, Markham/Gator and a number of generic grapples are this type. Imagine scooping up a rock in you hand with palm up. The thumb (upper grapple jaw) just keeps the rock from sliding or bouncing out of your hand as you walk.
Compare that to what I'll call a "pinscher" style grapple where the "bottom" tines are usually vertical (perpendicular to gravity vector). In this case the upper and lower tines must be pressing hard against the object or it will slip out. Kinda like picking up a rock with thumb and fingertips with you palm facing down. The WRLong and Anbo are well known "clamshell" styles that operate on the pinscher principle.
My basic point here is that the "gravity" style grapples do fine with a single partial length midline vgan!upper jaw. The pinscher style grapples almost must have a single full length double ram upper jaw (=more engineering and bucks).
