Sqdqo, Assuming Gary Fowler @ #5 is correct and you are talking about food plots to bring in wildlife, then all you need is a cheap method of cultivating to the level where winter growing seeds will germinate and flourish. That means a rough seed bed by farming standards. I would guess that I have brought more ground than most folks into farming cultivation in several countries, and that means to a higher standard than you require.
For your needs, and especially in the first, or pioneer, season, you cannot expect the level of growth you will have in future seasons. Disks and rocks are not a good combination. Neither do you need the fineness that disks will give you. At the same time you talk of "grass fields" suggesting the land has been cultivated in the past. I have farmed around the world and back again, and for many years have never used anything other than a tined implement. I used disc ploughs in Australia because I acquired them with the property. Tines are cheap, and provided you use a modicum of care, virtually unbreakable. Change the points when necessary and you have the one ideal implement for your purposes - except, how are you going to sow 13 acres? By hand is out of the question, and then you need to have at least a half-hearted go at covering the seeds, but again a fairly rough job is all that is needed. Sow thick, and drag almost anything over a rough seed bed and you should be fine.
Keep your costs down and use the biggest cheapest tined implement you can find that has spring loaded shanks for the inevitable big rock you will come across. 90 hp is plenty power to pull at least 11 tines. Be sensible, go just a few inches deep because you do not need more than 3 or 4 inches for what you intend to do. If possible feed the soil with a few bags of fertiliser. In following seasons you will be able to increase the productivity.
