Just bolted on a new Predator 212cc horizontal shaft engine on my 15 year old Generac pressure washer. The old Briggs wouldn't idle/run well at all any more except under heavy load. Unless under load, it yaws up and down as the governor kicks in than out. Took the carb off yesterday and cleaned it up as best I could with no improvement. Thought about getting a new carb for it, but after 15 years of use, I just didn't know how much more life it had. I put a new pump on the unit about two years ago, so a re-power for $99 with coupon seemed worth it, and the reviews on the Predator engines were all good.
So, after a simple swap out and adding oil and gas, it fired up on the first pull. The first thing I noticed, besides how much smoother it ran, was how much quieter it is than the old Briggs Intek. After checking to see that the pump will bolt right on, I left it off for the recommended 3 hour brake in so I didn't have to leave it hooked to my water supply. Hope it powers the pump as well as it runs once I get past the break-in period. (Put an hour on it today before the rain started AGAIN!). So far so good - pretty impressed for the money.
