RobJ
Elite Member
MrJimi said:Rob, did you disassemble your engine without draining the antifreeze?
I did that as a kid and it cost me a totally rebuilt engine?
Jim
Yep, you can see the gray bucket in one of the pics (actually the picture was taken while it was draining) I either didn't notice a block drain or it doesn't have one. Pulling the bottom hose would not have helped because I drained the radaitor using the drain plug.
The oil will be changed before start up so I'm not worried about a little that got down there. No damage to the cylinder because those were dried with compressed air and towels and wd40.
What was the reason you had to get a complete rebuild? I can't see the need for a rebuild just because a little water got down there unless it wasn't cleaned out or the oil changed? As long as you clean it up...no problems.
