Dmace
Elite Member
You need to fix your charted weights. Fords and Chevys can both go right up to the 26K line and keep on going. Dodge stops at 25400, period. Right off of the link to GM that you posted.
And as I've posted before, 7 mile long 5% grade, Dodge Ram dually Diesel will get out run by a Chevy 8.1L gas engine pulling the same GCWs.
And you need to learn how to read the ENTIRE POST before replying. I stated those were the max tow capacities while staying UNDER 26K GCWR! Can you see that now?
Gm and Ford's available GCWR's DO NOT go right up to 26K. GM goes from 24,500 to 29,000 (Not "right up to the 26K line"). Ford goes from 23,500 to 29,000 (Again, not "right up to the 26K line"). If you find different, I would love to see it and see what the tow capacity is with a GCWR UNDER 26K.
A GM gasser out-running a diesel up a grade while towing. :laughing:
That huge 8.1l will get about 5mpg up that hill and any newer diesel will probably get 15+mpg.
