newbury
Super Star Member
- Joined
- Jan 8, 2009
- Messages
- 13,605
- Location
- From Vt, in Va, retiring to MS
- Tractor
- Kubota's - B7610, M4700
That's an 8 yr old thread, it's probably in second grade by now.
For what it痴 worth, the local dealer transports my BX23 on a flat bed truck. The bed extends and tilts, the driver moves the BX onto the truck bed, sets the parking brake leaving the BX at a very precarious angle! The brake always holds. He then places the truck bed into its original position, having accomplished this task he continues by placing a binding strap, material composition unknown approximately 3-4 inches wide across the center of the BX - or maybe I should say the floor board area. After a quick ratchet of the binding strap, off he goes with the BX.
I must add that this is no small dealer they have very large equipment in addition to the Kubota line. I would say that they are a major player in the central Western Ohio region.
Why do folks automatically assume that because it comes from HF that it is improperly treated or metallurgical defective. Does anyone have real life experience where a chain from China or India failed prior to reaching the required tensile strength. Folks here are talking about mostly small CUT tractors that weigh less than 4000 pounds with all attachments and using 4 chains rated at 6600 WLL and 24,600# tensile and still worried about failure of a chain.No, but cheap and/or improperly heat-treated steel can have metallurgical failures. I hope not in your case, but for lifts/hoists/chains (or even straps) I don't feel guilty spending top dollar for name brands.
I guess we all have our own, individual demons--no offense intended, re: your choice.
The link to "Dargo's experience" didn't work for me. Any help much appreciated.
My Hoe
But I don't haul often or far. QUOTE]
Years ago a friend asked me to check out a small semi auto pistol that he intended to carry for protection. After testing it, I told him that it only worked about 50% of the time, and I wouldn't recommend carrying it. He replied that it should be OK because he wouldn't carry it often. I told him only to carry it during the working 50% period.
If you can trust the straps to travel one mile, you should be able to trust them to go 100 mi. If you don't trust them 100% , I wouldn't use them.
Best, Bill
