Sodo
Elite Member
- Joined
- Apr 21, 2012
- Messages
- 3,197
- Location
- Cascade Mtns of WA state
- Tractor
- Kubota B-series & Mini Excavator
I would not think of using a chainsaw, you will kill your back bending over and be filing the chain all day long.
I would use eqpt like this to cut it all off flush at the ground while standing upright. Drag it off the fence and make a dense pile that can't re-grow (or burn it). Then spray the new shoots that come up, which will require a tiny fraction of poison. I assume you want to get the stuff off the fence, so you might as well do that before spraying loads of poison on your land. Only need to poison what attmpts to regrow. The hard work is getting it off the fence (if restoring the fence is want you want). I would, I like split rail. Then it's an easy walk with a backpack sprayer. Depending on what vegetation you are battling, of course.
I use a brushcutter like the one shown, but use a skillsaw blade instead of that huge 10" blade. The 10" carbide takes too long to spin up, or spin down, consequently are more dangerous. Much harder to cut carefully around a fence without gouging it. 7 1/4" carbide blade is still an angry unit but much easier to guide it. 7 1/4" blade cuts a 2" stalk same as you might imagine a skillsaw cutting it, much faster than bending over with a chainsaw. And all the 1" stalks just go "TING !"
The 3-blade in the pic is useless in comparison to carbide. You probably have to modify the brushcutter to fit the diamond of a carbide skilsaw blade but its far superior to those heavy 10" carbide blades.
Prob should post a photo of your weeds/fence.
