GinNB
- Joined
- Dec 8, 2007
- Messages
- 336
- Location
- NB, Canada, eh?
- Tractor
- 2x Kubota M108S, M105S, 2x M9000, IH885, IH584, IH484, IH454, F3000, F3610, C50, JX70, Landini 5830, JD4630 sprayer
My .02. Pretty soon you'll have enough to buy a coffee for your buddy in town!
If I need a tractor NOW, I get it moving whatever it takes as long it's safe. For example, if a tierod bends while moving bucketsful of rocks down a steep rocky field and I plan to continue doing that then a mickeymouse fix isn't in the cards. If I hit a stump by accident and it's a rare occurrence then I'll either heat or put a pipe on whatever's bent. If I'm not confident in the long-term reliability of the fix then I add a note to my FixItList on my PocketPC so I don't forget. Every tractor and vehicle has an spot on my FixItList, so when I notice a problem it gets remembered the next time that vehicle goes in the garage. Every so often every vehicle gets a checkup and garage time for problems and preventive maintenance.
Depending on your vise and the bent part, lots of time the vice or the workbench gives way before the part straightens out. A heavy duty steel table is worth its weight in gold (or fixed parts). If not, even a 2x4 table secured to the wall with hardwood boards underneath for the vice to be bolted to isn't bad. I made do with a 2x6 table with a sheetmetal top for ages but got tired of trying to straighten big things by wedging them into tractor crevices (or whatever else was handy) when I needed some real strength. New welding table with heavyduty vise is 3.5'x5.5' and the deck is 3/4" AS400 plate with a reinforcing strip in the middle.
