jlsmith
Veteran Member
Have you looked at any on the MF. You might want to check out the MF1652L.
Jeremy
Jeremy
I don't know how the Mahindra weighs so much more than comparable tractors. Were you looking at a Grand L Kubota, they are really nice. This L4240 has plenty of power for what I do. I checked underneath my L4240 and with a magnet, and it is all cast iron. The 5035 is a slightly larger looking tractor to me.
I should say I think Kubota and Mahindra both build good tractors. I also suspect but can't prove that Kubota has spent more time and research developing their line of tractors and have worked out the castings and designs to a more efficient use of the materials. That is to say they (Kubota) have reduced the unneeded weight and are using high quality materials so that they can maintain a high degree of durability and strength in a lighter weight tractor. R & D and high technology cost more than the raw steel, you can add water or Rimguard for ballasting but it is hard to remove extra built in weight. Mahindra builds a heavy casting much like older tractors but with a lower level of technology I suspect but can't prove. I would say in Mahindras' defense that they are catching up fast though and will become higher tech tractors in the short term. You work with what you have and at this stage in Mahindras' development they are selling weight. I have only seen a few Mahindra tractors but they appear to be good solid tractors but lack some of the refinements of Kubota and Deere.
Just like some aluminum alloys are way stronger than cast iron.I agree with the above post, and would add that the type of steel used , and it's quality and , its treatments, or lack of, can make a lighter machine much stronger and higher quality than a heavier one. Junk "heavy" steal can be made that is barely stronger than sand glued together.
It is not just Kubota that they are heavier than. Check out this chart. i could understand them being 4000 or 4200lbs but to be almost 1700lbs heavier than the closest competitor, something somewhere is wrong. 1700lbs is a lot of iron. They say it weighs 5389 but I am wondering if it is a typo and supposed to be 3589? I have seen mistakes like this before on their site.
