rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 8,258
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
The other day an odd thing happened as I was driving the M59 back to where it sleeps.
I had been doing some backhoe crane work, & was just putting along at maybe 1800 RPM in high range with the dual speed (DS) lever in Hi. At a small incline I didn't change the foot pedal, pushed the dual speed lever down for Lo .... - and the tractor suddenly felt like I had stepped on the brakes and the engine stalled.
After checking it over I re-started and everything seems fine now - although I am not sure it is responding the same as it used to when the DS lever is in Lo.... I'm not quite sure. It sort of feels like it does in 4wd - but it's not. Like a slight bit of extra drag or if the brakes were slightly on. If anything changed, it's very slight & subtle. I usually work with the DS in Hi & set there it is just the same as always.
The next day it wouldn't start and that turned out to be a corroded battery terminal.... and that might have been the cause of the stall.
But now I'm a little suspicious of shifting to Lo & I'm wondering if anything similar has happened to anyone else with a HST+ transmission?
rScotty
rScotty
