Piston
Elite Member
Just to be clear to anyone still reading this thread... I did NOT know what I was doing when I took this cylinder apart. It's the first time I've ever seen the inside of a hydraulic cylinder.
I learned a lot from it, and if I was to do it over again, what I would have done was open the cylinder up, inspected it, and found the metal shaving holding the ball valve open (which I believe was preventing me from bleeding air out of the cylinder) and removed the metal shaving. I would unscrew the set screws for both ball valves (counting the number of turns it took) then applied some loctite and screwed them back in, adding one or two extra turns to increase the spring pressure slightly.
That would have fixed my problem.
Plugging the holes solid with JB Weld (which was my own idea based off the effects of alcohol convincing me it was the right thing to do) is not what fixed the cylinder. I also do not think anything bad will come of it such as the JB Weld coming loose. The only bad thing that I can see I could have caused is exactly what Jenkins posted about possible damage to the linkage or cylinder if I mistakenly miss to engage the locking latch when lowering the cylinders.
