Appreciate it piper184! I did find the below direction on this thread
3-Point Hitch - Farm Pro (Jinma) 2425 hitch will not stay up .It seems like the piston should just pull out but it doesn't seem to want to. Hopefully someone who has done it before will chime in and give me the courage to pry harder.
"Steps to rebuild the hydraulic piston -
1. Drain Fluid
2. Remove Gear Shifter Cover and Arms (you will need to do this to get the cylinder out, its in the way). (See Pic)
3. Pull out the cylinder. (See Pic)
4. Remove the piston from inside the cylinder, on mine it slid right out, the rings were bad, but if the rings have a good seal you will need to tap it on something while holding the cylinder upside down to get it to come out enough to get a grip on it.
5. Replace the ring and nylon washers (See Pic)
6. There is a arm that goes into the cone side of the piston which faces the rear of the tractor) this will drop down when you pull the cylinder out. You will need to pull the plate off the back of the tractor where the 3PH top arm connects and when you put the cylinder back in reach in and put the arm up into the cylinder cone.
7. Replace the 3PH plate, the cylinder and the Shifter and cover. Make sure the shifters line up with the linkage arms. This was not too difficult but took my several tries to line them up as well as the gasket. I had to put the cover on and get the tractor in Neutral in order to line up the shifter with the linkage arms, there are three arms, one for High and Low, and the other two are for Reverse and first gear, the other for second and third gear. You can see them in the picture.
I hope this helps anyone with the same issue I was having. It was much easier to do than I thought. I wish that I would have tried it myself first and saved the $277 that the John Deere dealer charged me to look at it and not find anything wrong."
Good Post Quote Reply
Report
