kennyd
Advertiser
Like many, I've been looking for a way to increase the lifting capability of my front end loader.
I've researched adding larger hydraulic cylinders and while this is more than doable, the shim change is a lot quicker, easier, and much less costly. I see the stock setup is configured with one solid flat shim and one flat washer. Knowing that by adding a shim simply changes the preload on the valve spring slightly therefore increasing the fluid output pressure. Instead of spending a lot of dough on the item + shipping, I'm wondering if adding a 12mm x 0.5mm flat stainless washer on top of this stack would result in the same performance change?
Comments are greatly appreciated!
Yes, a "shim" is just basically a washer-no real need for it to come from a dealer. BUT: please make or buy a gauge setup and take before and after measurements, do do not want to increase it to much. 10% or so seems to be the general consensus on that.
